Widening the XW and XW+ HBCO and charge voltage for Ni Fe batteries
Dave Angelini
Solar Expert Posts: 6,749 ✭✭✭✭✭✭
You can upgrade the legacy XW6048 to XW+6848 firmware and have all the latest functions and features.
Just rename the file and the Combox will allow the upgrade (i.e. change 865-6848-01 to 865-1000)
You can then set HBCO to 70V to prevent nuisance tripping.
The latest firmware for MPPT80-600
mppt-80-600-firmware-v1-02-bn0003increases the trip level to 68.2V (Warning) and 69.3 (Fault) respectively.
I have not tested this and Combox should be latest firmware before you try this.
E-mail offgridsolar@sti.net
I would do that in a heartbeat, to accommodate my winter time generator charging, IF I knew the electrolytic caps can take that voltage.
If it were me, I would get a spare or do just about anything to avoid listening to a generator run any longer than absolutely required.
I have a client in the desert of Arizona that has been running an XW since 2006 in a hot metal shed. They are built for it if you clean the filter and keep the fan running. Not to hard to do"we go where power lines don't" Sierra Nevada mountain area
