Inverter won't start
trAxe3trAxe3 Posts: 3Registered Users
Hi there. Recently I installed a solar water pump system, model SI-10 VEICHI . The entire day it works normally..but in the morning it won't renew it's activity. In the night it turns off, in the morning it should turn on automatically..so it does, but frequency 0.00 Hz is displayed and it won't start inverting). All settings are by default and wires conected properly.
Any ideas? Thanks!
  • EstragonEstragon Posts: 2,775Registered Users ✭✭✭✭
    Is it connected to a battery, and if so, what is the size and state of charge?
    Off-grid.
  • trAxe3trAxe3 Posts: 3Registered Users
    It does not have a battery or other storage devices. As I understood, it should turn on by itself when there is enough solar energy. The LED light on the "FWD" button should be always on, but after night break it is off and 0.00 Hz is shown.
    My father asked me to find any solutions to this problem and i don't have knowledge in electrical engineering :(
  • mike95490mike95490 Posts: 7,874Solar Expert ✭✭✭✭
    A link to the mfg's web page or manual would be helpful
  • SolraySolray Posts: 246Registered Users ✭✭
    edited July 2017 #5
    http://veichielec.com/1-1-solar-pumping-inverter/203087
    Search engines are wonderful things.
    @solray - so do you have the solution?
    Off-grid.
    @trAxe3 - what is the configuration of the solar input, and the pump?
    Off-grid.
    @Estragon all settings are by default. Yesterday we tried to reset to factory values, but still no improvements.
    Here is the manual of the inverter http://en3img.allhaving.com//upload/2972/o/1_1_6_tension_control_frequency_inverter_2.pdf
  • mcgivormcgivor Posts: 2,164Solar Expert ✭✭✭✭✭
    edited July 2017 #9
    This" inverter" appears to be a variable  frequency drive, the manual has no mention of solar input, that I saw at least, it shows  an AC input, which has me thinking there is more to the system. How is the solar connected? DC in to the inverter?
