Have you ever seen Unusually High Power readings reported by Enlighten Monitoring
MarcF
Registered Users Posts: 5 ✭✭
I was checking the performance of a recently installed Grid-tied residential PV system through Enphase Enlighten Monitoring and noticed something strange. The system consists of 10 REC TP2 290 Watt PV modules each paired with Enphase M250 micro-inverters. Looking at the Time lapse view for Power, at one point during the day, 2 of the micro-inverters show 450+ Watts being produced, while the neighboring 8 REC290/M250s each produced around 230 Watts. The most i have ever seen produced from a M250 micro-inverter was around 259 Watts (it was paired with a 315 Watt panel). If they are supposed to max out around 250 Watts, what could explain the 450+ readings? Has anyone ever noticed unusually high power readings with Enphase micro-inverters? I suspect this is a glitch in data reporting, unless these micro-inverters can produce this amount of power briefly before clipping?
Reboot your local interface?
What seems odd is the system power, lower left corner is consistent with all the displayed panel outputs in the graphic, ~2.74kW, but if the two "false? " readings were substituted for the average of the others, it is consistent with the today peak of 2.34 kW, must be a glitch, a 290 W panel could not put out 450 +W. Curiously double the average output is in the 450W neighborhood, perhaps a setting error? or as Bill suggests, reboot, the standard fix for software glitches, when nothing else works. Have no personal experience with Enphase, just some observations, FWIW.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
The roughly 2x thing is kind of interesting.Off-grid.
I would call your installer and get them replaced (the enphase converters).
Rancher -
Reboot and if it fixes the problem, see if there is a fota update you missed.
