Water leak
abdulaabdula Registered Users Posts: 1
I have a water leak from my RTU unit to the panel should o change the conduit and wire or wire putty it
  • LumisolLumisol Registered Users Posts: 374 ✭✭✭
    Make sure you fix the leak first then allow for everything to dry thoroughly (several days) and make sure your conduits are all watertight. Then try restarting it.
  • solarvicsolarvic Solar Expert Posts: 1,043 ✭✭✭
    What is an RTU?
    Roof top (air handling) unit.
