Will this combo work? 330watts pv on blue sky controller
ayurtdweller
Registered Users Posts: 26 ✭✭
I am looking for a low cost, high power mppt controller and have come across this. Blue Sky 1524ix
http://www.blueskyenergyinc.com/products/details/solar_boost_1524ix
It gives max input ratings for a few different pv cell configurations. I'd like to use it on a 12v battery using one of these panels: https://www.civicsolar.com/product/canadian-solar-maxpower-cs6u-335m-335w-mono-slvwht-1000v-solar-panel-t4
Is this a dumb idea?
Output Current Rating | 20A max (12V battery & 12V PV’s) • 15A max (battery or PV’s > 12V nominal) |
Nominal Battery Voltage | 12 / 24 VDC |
PV Input Voltage | 57VDC max (Recommend max Voc at STC ≤ 45.6VDC |
Module Watts STC:
335 Watts
Module Watts PTC:
307.10 Watts
Max Power Voltage (Vmpp):
37.80 Volts
Max Power Current (Impp):
8.87 Amps
Open Circuit Voltage (Voc):
46.10 Volts
Short Circuit Current (Isc):
9.41 Amps
Where are you located? The Voc could be a problem, because on a cold morning before the sun hits the panel to warm it up the voltage could get too high. A slightly smaller ( eg ~250w) panel would likely have a low enough Voc.
If the panel can never get cold in your location you might be able to get away with it.Off-grid.
New Hampshire....cold enough!
Temperature Coefficient (Voc) -0.31 % / °C
Probably doesn't get cold enough there to overvoltage (we see <-40C here), but you might want to consider the smaller panel to be sure. The panel will be a little easier to handle physically as well. The bigger ones are definitely a 2 person job to handle.Off-grid.
