Looking for a Solar array angle comparision site?
So I use to have the site tabbed, many computers ago, that let you plug in the direction and angle of your array and compare monthly output. I can't find the site now. Anyone have this in their tabbed solar sites?
I finally installed my East, South East array to catch morning sun and would like to compare angles and output, Right now it's leaning against my porch, which is fine but I need to finish and put bracing to the back of the frame. It can and will, somewhat lean over the porch, if I won't lose much I might make the top in line with the porch. About a 20 degree difference from 55 to 75 degrees.
Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
0
Steve
This one is pretty simple and has lots of international locations... Although at times, it mixes up the state of Georgia and the Eastern Europe Georgia...
Anything specific from a solar calculator you are looking for?
"Requested Location:","san mateo ca"
"Location:","SAN FRANCISCO, CA"
"Lat (deg N):","37.62"
"Long (deg W):","122.38"
"Elev (m):","5"
"DC System Size (kW):","3.5"
"Module Type:","Standard"
"Array Type:","Fixed (open rack)"
"Array Tilt (deg):","20"
"Array Azimuth (deg):","180"
"System Losses:","14"
"Invert Efficiency:","96"
"DC to AC Size Ratio:","1.1"
"Average Cost of Electricity Purchased from Utility ($/kWh):","0.16"
"Capacity Factor (%)","17.7"
"Month","Day","Hour","Beam Irradiance (W/m^2)","Diffuse Irradiance (W/m^2)","Ambient Temperature (C)","Wind Speed (m/s)","Plane of Array Irradiance (W/m^2)","Cell Temperature (C)","DC Array Output (W)","AC System Output (W)"
"1","1","0","0","0","3.9","2.1","0","3.9","0","0"
"1","1","1","0","0","4.4","3.6","0","4.4","0","0"
"1","1","2","0","0","2.8","2.1","0","2.8","0","0"
"1","1","3","0","0","3.9","0","0","3.9","0","0"
"1","1","4","0","0","1.7","1.5","0","1.7","0","0"
"1","1","5","0","0","1.7","1.5","0","1.7","0","0"
"1","1","6","0","0","1.7","1.5","0","1.7","0","0"
"1","1","7","32","14","2.2","0","22.629","-1.012","69.804","49.045"
"1","1","8","363","49","2.8","0","206.482","8.825","617.984","585.53"
"1","1","9","590","73","5.6","0","423.381","21.962","1253.362","1203.692"
"1","1","10","701","90","6.1","1.5","594.559","23.144","1782.286","1715.285"
"1","1","11","749","100","6.7","2.1","694.045","25.297","2071.674","1994.039"
"1","1","12","750","103","7.2","2.1","708.536","26.464","2105.07","2026.154"
"1","1","13","711","101","7.2","1.5","642.563","26.639","1901.646","1830.357"
"1","1","14","650","81","7.8","0","506.732","30.192","1457.836","1401.79"
"1","1","15","483","60","7.2","1.5","304.39","16.229","904.945","865.203"
"1","1","16","137","28","6.7","1","81.172","8.542","237.9","213.866"
"1","1","17","0","0","6.1","1.5","0","6.1","0","0"
"1","1","18","0","0","4.4","2.1","0","4.4","0","0"
"1","1","19","0","0","3.9","1.5","0","3.9","0","
I'm actually capable of doing the math, but it would take some time for me to setup. I'm much too lazy for that...
I think I have my answer and will check Bills hourly, and see how it works.
West Chilcotin, BC, Canada
2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
http://www.solarpaneltilt.com/
Unfortunately, for @Photowhit the site provides info on tilt, but not azimuth.
Steve
