Bulk charging with generator help
SketchassSketchass Posts: 1Registered Users
I've been using my 3500k watt generator to bulk charge through my xantrex inverter. Everything has been fine until recent. Now, when I need to charge my batteries via generator, the generator loads up and then trips the breaker switch on the generator after about 15 seconds. I've researched more internet than I ever wanted bout this topic. Any help would be more than grateful!!!
  • oil pan 4oil pan 4 Posts: 669Solar Expert ✭✭✭✭
    Exactly what generator, charge controller and battery do you have.
    Sounds like the breaker is doing its job.
    Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
    Solar roof top GMC suburban, a normal 3/4 ton suburban with 180 watts of panels on the roof and 10 amp genasun MPPT, 2000w samlex pure sine wave inverter, 12v gast and ARB air compressors.
  • mike95490mike95490 Posts: 7,562Solar Expert ✭✭✭✭
    cheap circuit breakers wear out and start to trip at lighter and lighter loads.
  • jonrjonr Posts: 930Solar Expert ✭✭✭✭
    A clamp on rms AC ammeter can measure the current (ie, verify that the circuit breaker is correct).
