Watt meter help
littleharbor2
Solar Expert Posts: 2,039 ✭✭✭✭✭
Does anybody else have one of these in use. I have 3 of them that have been kicking around for a while. They don't have any instructions and all the overseas venders are of no help. There are a red and black wires for line and load and a small port. I have seen these pictured in a discussion here in the past. Seems the port would accept a modular plug wired to a shunt maybe, but they aren't sold with any such modular plug nor instructions.
Found this youtube, it appears to have a 100 amp shunt built in.
https://www.youtube.com/watch?v=LUuPvfDmSZM
4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
You can read about a similar meter here:
http://www.rc-electronics-usa.com/electrical-test-equipment.html
Thank you both. I will go through the text and video.
If it is similar to others, it is not rated for 100 AMPs continuous.
http://www.rc-cars-planes.com/docs/wu100v2_user_manual.pdf
Camden County, NJ, USA
19 SW285 panels
SE5000 inverter
grid tied -
I would suggest that most of these types of devices are way over spec'ed... 100 Amps for a second? Probably closer to 15-20 amps max continuous (from the typical wiring size).
I made the connection between CC, (source) and Battery (load) trying to measure charging of my battery and the unit wouldn't even light up. Maybe this is a bad unit.
At least I have found out the port is for aux. power when measuring small voltage sources.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
