PWM controller rating question
S2T_Bama
Registered Users Posts: 8 ✭✭
Hi All,
I hope this is a simple question. I have read and believe I understand that MPPT charge controllers are essentially rated by the battery charging amperage.
But, I was looking at the PWM CC's in the sponsor's store, e.g. OUTBACK POWER SMARTHARVEST 10 AMPS 12/24 VOLT.
I would have thought that the amp limitation would correspond to the Isc for the panel(s) being attached. An example would be a KYOCERA150 WATT 12 VOLT panel with
Basically, I thought the panel will really never produce more than 8.87A. Is that correct?
But instead the specs for the Outback CC indicate a maximum PV power of 120W = 12V x 10A.
I thought the PWM technology doesn't use transformers and thus couldn't increase the panel's "native" amperage. Is that not right?
Thanks for your help understanding the terminology!
Open Circuit Voltage (Voc) | 22.5 Volts |
Short Circuit Current (Isc) | 8.87 Amps |
It is my understanding also that PWM controller current output won't exceed input current. Pmax could be higher than Pstc if the panel was really cold at very high altitude though.Off-grid.
As Estragon said possible, but not likely. Even in cold areas panels warm up as the sun hits them. Mine will cut the frost/ice glaze in just a few minutes of direct sun. Mostly it's the voltage that rises, increasing the overall power output.
Usually you can use the IMP since panels will usually warm before direct good angle sun light. Some can even handle a bit of over current!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
