Missing Grundfos part
Ravemind
Registered Users Posts: 12 ✭✭
Hi Everybody,
I thought I would look to you guys for help this. I have a Grundfos IO 101 control box that is missing the AC cable. It would be nice to see if I can find the cable or make something compatible rather than removing the connector and hard wiring to it.
Why don't I contact Grundfos? I have contacted 4 authorized Grundfos dealers and they all said "Let me look into that for you and find a part number." Not a single one got back to me. In my searching online I never found a part number either.
I poked around at Digikey but it's beyond me. 1,000 circular connectors and not many have photos.
Anybody know what the connector is and where I can get it?
Jon
Jon
Main property - 4.5 kW panels into 2 x Schneider MPPT60 150v charge controllers | Schneider Conext SW4024 Hybrid inverter | 30 kWh of Lithium Batteries 24V - Water pumping - Grundfos SQflex | 1000w solar panels | Midnite Solar theKid | 48v Lithium battery |
I believe this thread may help you. Looking for a CA3GS from Hirschmann (Germany):
http://cr4.globalspec.com/thread/84291/Need-Help-Identifying-a-Connector-Manufacturer
http://www.newark.com/hirschmann/ca3gs/connector-power-entry-plug-16a/dp/06WX5699 (socket you have, find plug that mates the way you need it).
Doh, I didn't read the CA3GS correctly. I was googling CA36S.
This is the matching connector.
http://www.newark.com/hirschmann/ca3ld/circular-connector-receptacle/dp/70C6862
Thank you very much for your help.Main property - 4.5 kW panels into 2 x Schneider MPPT60 150v charge controllers | Schneider Conext SW4024 Hybrid inverter | 30 kWh of Lithium Batteries 24V - Water pumping - Grundfos SQflex | 1000w solar panels | Midnite Solar theKid | 48v Lithium battery | -
I read it the same way... I put "Germany" in the search with CA36S and found that thread.
Happy you found the mate!
