Solar panel watts&amp output
Jerry17
Jerry17 Registered Users Posts: 3
edited January 2017 in General Solar Power Topics #1
Hi,
 I have 2 130 watt panels on my RV for a total potential of 15amp output per hour if my battery is low in the morning.
A friend recently installed one 260 watt panel on her van that is rated for about 8amps output per hour.
 Can you explain this?
Edited.
    It is a bit more complicated that that... Assumign your friend has a MPPT type solar charge controller--they are doing just fine.
    You probably have a PWM charge controller--Which is fine for your installation
    Power = Volts * Amps.
    A PWM controller "lets through Amps"... I.e., (forgetting losses), 15 amps in is 15 amps out.
    A MPPT charge controller is a "down converter"... A DC switching (buck mode) power supply. Again, ignoring losses, the MPPT controller takes Watts in and outputs the same Watts out:
    • Power = Voltage * Current; Current = Power / Voltage
    • 260 Watt / 14.5 volts charging = 17.9 amps out
    • Including losses: 260 Watts * 0.77 panel+controller deraiting * 1/14.5 volts = 13.8 amps typical maximum current
    A PWM controller:
    • 260 Watts * 1/18 volts Vmp = ~14.4 volts Imp (current maximum power)
    Realistically, if both installation are properly designed and installed, they have about the same output.
  • Jerry17
    Thanks for that explanation. I had been faked out by the 8 amp rating on the label while misunderstanding the different types of controllers. I had kind of thought the panel might have been 24v but anyway... last thing I needed to know. heh.
  • Jerry17
    Hi,
     Well, I found out now that her controller is a PWM Sunsaver 20 by Morningstar. So, she is getting only the 8amp rating to the battery?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,037 ✭✭✭✭✭
    Yes, and that 260 watt panel is putting, at best 115 watts into her batteries.
    This is a good small MPPT controller (get the remote battery temperature sensor option) for your friend (the 260 Watts of panel is about the largest that this small controller will run on a 12 volt battery bank--Would need a larger controller if more panels added later:
    https://www.solar-electric.com/mosumpsochco.html ($200 + RBTS cost)
    There are a lot of larger MPPT controllers to pick from out there...
