Conext Battery Monitor - problems
fasterski
Registered Users Posts: 13 ✭✭
Just wondering if anyone has come accross this issue.
I have just installed a small system with battery backup using SW4024. I'm having a heck of a time with the battery monitor. It displays the information on the screen about the battery bank. Yet it does not seem to be reporting the information on the Xanbus. It shows up on the combox and scp panel but the values are zero. When I try to update it via scp it throws error 250 unable to update data.
I have noticed it is running firmware 1. When I try to update it via combox it goes through the process and all seems well. Yet on the reboot of it i comes back with the old version. I have also noticed that the power / reset button flashes red all the time (there is a slight period of time < 30 sec) that I see it flashing green when it it reset.
What gives?
What gives?
Is the Xanbus termination plug installed in the 2nd jack of the Monitor ? BOTH ends of Xanbus need termination
Yes I have terminated it as per instructions. I was able to flash the firware OK. The orange light still keeps flashing. I can't find anywhere any reference of what that would indicated. Maybe the thing is just DOA.
fasterski said:Yes I have terminated it as per instructions. I was able to flash the firware OK. The orange light still keeps flashing. I can't find anywhere any reference of what that would indicated. Maybe the thing is just DOA.
