Power Optimizer AND charge controller?
openplanet
Registered Users Posts: 34 ✭✭
I have a 2kw array and a Midnite Classic 200. Is anything to be gained by adding power optimizers to the array? I know this might be a stoooooopid question, but then again, we may learn something from the answers. Thank you.
My understanding is that an power optimizer is itself a MPPT device and DC DC converter which is connected to an individual panel, optimizing the output of that panel, one per panel is used and the outputs are sent to a grid tied inverter vIa a monitoring portal . Would there be any benefit using them in conjunction with another MPPT controller? Perhaps since it would take an optimized voltage and further optimize it. That's no stupid question,it's an interesting question, the only other question is would it be cheaper to add to the array instead.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
openplanet said:I have a 2kw array and a Midnite Classic 200. Is anything to be gained by adding power optimizers to the array? I know this might be a stoooooopid question, but then again, we may learn something from the answers. Thank you.
You may have seen this warning in the later versions of the Classic Manual,
It is not clear what, if any benefits Optimizers would provide.FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
