What advantage to an outback hub?
Freewilley
Solar Expert Posts: 228 ✭✭
Since I have become aware that one Remote Temperature Sensor is not enough, I am faced with purchasing two more or getting a Hub to have my three outback products managed by my Mate.
The Hub will cost $100 more, and I am wondering what I get for that....
I looked at the Mate manual and do not see what advantage there is...the one I can think of is that I could limit the amount of solar going into my bank with the mate. Currently when I isolate one string of my bank I limit the solar through settings on each CC...this is not always the most efficient way, but the difference is probably very small.
Anybody know enough about Outback to comment? I have applied to join the Outback forum but am still waiting for approval so I can post this question...
thanks!
thanks!
Mate, VFX 2812, FM 60 & MX 60, 2 Full River AGM 400 6v, 1400 watt Solar Array, Yamaha 3000iSEB inverter gen
12 volt Flojet water pump
off grid summer home in northern Ontario
The Outback forum is about as exciting as a trip to the morgue....in my experience. I have the Outback MATE with all of the bells and whistles. Could be useful to a techie. I think you can check on things remotely? Which means that it can be hacked....
If you buy everything that some of the pro$ insist that you need, you may be Chapter 11 in awhile. Just my humble .02 .
It took me about a week or more to get approved on their forum. Pretty slow paced forum but their IS a lot of good reading in the archives from the many years they have been around. Once you get through that don't hold your breath waiting for any amount of activity.
I have put this question up on their forum...but does anybody here have a hub and one FX?????Mate, VFX 2812, FM 60 & MX 60, 2 Full River AGM 400 6v, 1400 watt Solar Array, Yamaha 3000iSEB inverter gen
off grid summer home in northern Ontario -
The outback forum has not come up with any benefit to a hub, beside the convenience of using the mate for programming.Mate, VFX 2812, FM 60 & MX 60, 2 Full River AGM 400 6v, 1400 watt Solar Array, Yamaha 3000iSEB inverter gen
- 299 In the Weeds--Member's Choice
