SRP rules about grid tie (grid zero mode, not feeding grid)
jimmyaz
Registered Users Posts: 114 ✭✭
Hi All,
Can anyone tell me if it's a requirement to get permission or sign contact with SRP if I am doing a grid tie system using OutBack Hybrid Inverter but running on GRID ZERO mode = Does not feed any power into the grid at all. The Outback inverter should act like a appliance and it's USING power, not grid feeding.
I understand that the system require a license electrician to do it... But if I don't want credit from SRP and not feeding the grid... can I do it without SRP consents?
thanks
thanks
You can do this yourself if you take a permit out from the building department as an owner/builder in most US states/Canada and of course have the skill. They will know what you need to do or where to look. It can be smooth or a pain depending on your county/state.
It is a challenge to do this correctly without deeply cycling batteries that are commonly available right now.
If I were you I would wait a little longer unless there is some burning reason why you need to do this."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net
