1500 volt Voc GT Inverter system from Tigo
Dave Angelini
Solar Expert Posts: 6,746 ✭✭✭✭✭✭
Hot off the press!
Tigo’s TS4 platform recently got listed by CSA under ANSI/UL std.1741, CSA 22.2 -01 requirements. TS4 product designs are fully certified and are ready for design and installation to support 1500V grid-tied PV system.
Technically, raising the system voltage to 1500 volts allows for 50% longer strings, which eliminates 33% of the combiners and wiring in a system. The longer string enables a higher inverter input voltage, which supports an increase in the inverter’s rated output power by 40% to 70%. With its currently shipping Long String feature, Tigo® further improves the customer benefits beyond the 1500 volt capability. TS4 gives installers a greater degree of control over what they want and need for any given project, big or small.
Tigo® re-shapes the solar industry by shipping the First 1500V certified Flex MLPE
Supporting PV installations of 600V, 1000V and 1500V systems
worldwide
E-mail offgridsolar@sti.net
