Expected output of a panel.
SolarLakeHouse2
Registered Users Posts: 16 ✭✭
What would be a reasonable max output from a solar panels listed output? Say a 12v 160 watt 8.62
Depending on the controller, the maximum could be over the nameplate rating of 160 watts. The typical output is about 77% of that (including controller losses).
--vtMaps
Max you get from a panel like that would be about 20 volt and 6 or 7 amps.
