Wire Size
xyzHollyxyz
Registered Users Posts: 24 ✭✭
I currently have 1 x 100W 12V flexible solar panel to hopefully charge my little travel trailer Group 31 battery.
The only thing I need that battery to do is keep the fridge control board running while on propane.
(and I suppose the CO/propane sensor...)
What gauge wire should be used from the panel to the controller (no more than 30 feet)?
Controller is PWM.
Would the wire size change IF I decide to add one additional 100W panel?
Thanks for your help.
Controller is PWM.
Welcome to the forum,
with 1 panel, 10 gauge copper wire will give you less than 2% voltage drop. Two panels should have 8 gauge.
If each of the two panels has its own 10 gauge cable (combine them near the controller) that would also work well.
--vtMaps
Thanks for the welcome and thanks for the reply!
As a follow-up, until, and if, I get the 2nd panel, can I use 8 gauge on the single panel so I don't have to re-make the extensions? For a rank amateur like me, that's no easy task!!
And a rank amateur question - a less than 2% voltage drop is a good thing, right? Will larger gauge wire (smaller diameter) give me a bigger voltage drop? That means a power loss going into the battery? -
xyzHollyxyz said:a less than 2% voltage drop is a good thing, right? Will larger gauge wire (smaller diameter) give me a bigger voltage drop? That means a power loss going into the battery?
Now having said all that, I'm having doubts about the numbers I mentioned earlier... I did the voltage drop calculations for an MPPT controller where the transmission voltage is Vmp. On a PWM controller, I believe the transmission voltage is just a fraction of a volt above Vbatt (the battery voltage). In that case, your percent voltage drop is a bit higher than I calculated.
Does it matter? Usually not... the volts you lose were never going to be harvested anyway... that's the nature of a PWM controller.
--vtMaps
