reset to factory default OB FX3048t
vince
Registered Users Posts: 79 ✭✭
I know that a mate has the option to reset the settings of the inverter to the factory default. Is there another way to do that without purchasing a Mate? Perhaps by doing a firmware update?
Sunpower 3 x 435 watt panels, 48 v 215 AH battery bank (Sam's club), Midnite Kid and WBjr, Fujitsu 9RLS3 split duct AC, Outback FX 3048T + transformer 2000W 120/220V, GrapeSolar Fridge.
Well, a firmware update requires it to be send to the factory, so that is not practical. No reset button?
Sunpower 3 x 435 watt panels, 48 v 215 AH battery bank (Sam's club), Midnite Kid and WBjr, Fujitsu 9RLS3 split duct AC, Outback FX 3048T + transformer 2000W 120/220V, GrapeSolar Fridge. -
Why would you have an outback inverter without its mate? It's hard for me to imagine a system in which the default parameters are correct for the system.
--vtMaps
Outback support told me there is no way to do a reset without a mate. Oh well. If I only use one inverter and not a generator or other outback products and not interested in selling energy back to the grid, the default setting are fine to start with.
vince said:Outback support told me there is no way to do a reset without a mate. Oh well. If I only use one inverter and not a generator or other outback products and not interested in selling energy back to the grid, the default setting are fine to start with.
The reason Outback sells inverters without mates is because if you are buying several of their inverters to make a large stacked system, you only need 1 mate. The reason the controls (the mate) are not built into the inverter is because some folks want to mount the controls remote from the inverter.
--vtMaps
