solar backup lighting advice
Any advice would be great. Everything is in the picture..
thanks in advance
PS YES I know i got the solar charger red and black wrong on the pick. .. OOPS.
What do you want to power when the grid goes down?
Only lights? If it is only lights that you want when the power goes out, why not use a emergency light that could be bought at hardware stores like lowes hardware.
Or , use a UPS (uninterrupted power supply)
That dimmer in that picture is not the best. I went through 2 of those where one stopped responding and the other started to smoke. I got 2 of those dimmers on the same circuit and if I dim both of them , then both of them will have a flicker which makes me believe that they feeding back at a frequency to each other. It does not flicker with full brightness. One time I had 14 some volts on the circuit and that dimmer did not like it, it made the LED strip like you pictured blink in 1second intervals to on and then off again. When I reduced the voltage to about 13 volts the LED lights turned back to normal again.
A while back, I seen a 24 volt version of those LED strips which could save you from having to buy a step-down converter.
Why not just buy a normal off the shelf LED emergency light?
none of that gives me any advice to go with 12 volt or a 24 volt system.
Most of the LED lights out there will run on native 12 volt, you just have to hunt and read the specs..
ie http://www.ebay.ca/sch/i.html?_odkw=mr16+LED&_osacat=0&_from=R40&_trksid=p2045573.m570.l1311.R6.TR10.TRC2.A0.H1.Xmr16+LED+12v.TRS0&_nkw=mr16+led+12v+dimmable&_sacat=0
12V is for limited size systems. The wire gauge/Voltage loss requirement is the deciding factor. The higher the loads and the longer the runs, tend to push more toward 24V or higher.
But first loads have to be calculated. Can you use 16 ga lampcord or do you need 8ga wires for a 300' run ???
Most emergency light systems use 12 volts. So....
katet1919 said:none of that gives me any advice to go with 12 volt or a 24 volt system.
This way you have at least a light when your grid goes out.
Hello Katet,
I have a similar setup and went with 24 volts due to 120 feet from the batteries to the '24->12 volt converter'. I not only run my under-cabinet kitchen lights, but my Cradlepoint router, Synology NAS, Security DVR and IP cameras. 24 volts can use a smaller gauge wire carrying half the current, but the same Watts, for longer runs.
I would expect you will need a DC-DC converter (24->12 or 12->12) either way you go. The voltage on the batteries/charge controller will fluctuate widely. My 24 volt system goes from 24.8 in the morning to 28.5 during absorption charging daily. So, you could expect a 12V system to go from 12.4(or lower if power is out a long time) to 14.3(or higher). Most DC-DC converters have a wide input range and a steady output. If you don't use a DC-DC converter, make sure your LED lights have a wide operating voltage.
-Joe
