Fronius IG Plus vs Primo 11.1/11.4
quique
Solar Expert Posts: 259 ✭✭
I have installed Fronius IG Plus A 11.1 with 4 strings of solar panels connected to them, interfacing to a 240VN uniphase grid.
Im looking over the Fronius Primo 11.4 but Im unsure if should use it. The datasheet says it can either be used with 2 MPPTs or 1 MPPT. According to their tool, with 2 MPPTs I can get:
5 strings of 9 panels each on MPP1 and 3 strings of 9 on MPP2.
If I combine the MPPTs (which I guess is a jumper or some other setting on the inverter itself) I can get:
5 strings of 8 panels.
What would the advantage of the separate MPPT be? In case some strings are in a less than optimal location vs another set of strings?
MPPT estimates the optimum solar array voltage.
Mostly, this voltage varies with number of cells/panels in a string (your physical design) and the cell temperatures.
This gives you the option to have different numbers of panels how many you can fit on s roof plane) and/or optimize the energy harvest with different roof plane (facing southeast vs southwest).
As always, read the specifications & manuals closely. There maybe limitations in array configurations that a single 2 input gt inverter beyond the basic Voc/Vmp limitations.
The IG+A inverters are transformer based, while the primos are transformerless. The latter will be lighter, safer, slightly more efficient, and easier to install.
Ethan Brush said:The IG+A inverters are transformer based, while the primos are transformerless. The latter will be lighter, safer, slightly more efficient, and easier to install.
I believe that ungrounded, transformerless inverter systems can detect lower fault levels and do not have the ground fault "blind spot" issue that has caused fires (think bakersfield).
