Victron energy 150/70 problem
Solarboat_team_NL
Registered Users Posts: 2 ✭
Hello,
I am from a dutch solarboat team called Sinnergy.
We have a Victron Energy 150/70 MPPT.
We have tried to extend the ribbon cable so the circuitboard with the display could be in the cockpit.
But now the problem: now almost every time we get in the menu of the MPPT we get a warning message even with the original ribbon cable.
The warning message reads inf.21, does anyone know on this forum what this means?
The weird part of this warning is that with the original ribbon cable the warning message sometime just gone is.
Thanks in advance.
Kind regards,
René Venema
Sinnergy Solarteam
Netherlands
Thanks in advance.
Kind regards,
René Venema
Sinnergy Solarteam
Netherlands
Sorry--I cannot find any information on Int 21...
I will bump your question so others can see it.
Good Luck,
Is the Firmware up to date of the MPPT150/70?5kVA Victron Multiplus II, 5.2kW array, 14kWh DIYLifepo4 bank, all grid-tied.
We have found the problem.
It turns out it was very simple.
The ribbon cable connector was a bad quality, so if you pushed them togheter 1 or more pins did not make contact with the ribbon cable and that caused the problem.
Thanks for searching and I hope that someone else has something about this solution.
P.S. if anyone likes to follow the event, you can find information here:
http://www.dutchsolarchallenge.nl/en/
Kind regards,
René Venema
Sinnergy Solarteam
Netherlands
