CC, Box Enclosure, Battery
Zakarume
Solar Expert Posts: 143 ✭✭
question. If you have 2 more CC. Could you run the wires from CC to a http://www.solar-electric.com/baby-box.html to act like a combiner box and then run the positive and negative cable to battery
1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
You need some sort of DC disconnect as a place to accommodate the primary buses and circuit protection. Exactly how big a disco really depends on how much stuff you need to put in it. A Bigbaby box might be suitable for a small couple of panel system. But once you need an inverter breaker of any size that puts you into MNDC or epanel territory.
- 898 Solar Product Reviews & Opinions
- 654 Solar Water Pumping
- 620 Discussion Forums/Café
