36 Volt DC light for 24 volt system
malborn
Registered Users Posts: 1 ✭
Hi
I am so curious about that: Let's say I have:
36 volt dc LED light
2 x 12 volt panel (24 volt)
2 x 12 volt battery (24 volt)
1 X 15 amp mppt solar controller
can I connect them to charge controller directly without using converter ? If ı need to use dc to dc converter where should I connect ? between load terminal of mppt and light or between batteries and light ?
thank you
thank you
It will certainly work properly if you put your DC converter between the battery and the light. What the load terminal can do and will do depends on what controller you have. Do you need the control functions that load te
--vtMaps
- 227 Forum & Website
- 135 Solar Forum News and Announcements
- 198 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 617 Discussion Forums/Café
- 310 In the Weeds--Member's Choice
