Smart Switch for solar/utility/gen set
syedbukhari
Solar Expert Posts: 104 ✭
Hi i am searching for a smart switch that can control the all energy resources with priority basis.
I want to apply this switch on 48 volt DC system. The detail is as follows.
We are running a 48 Volts DC system. We have four sources to run this system,
1) Solar
2) Utility
3) Battery
4) Gen set
The scenario is load and batteries should charge from solar at day time when the battery voltages go down below 49 v then the utility should get on and if the utility is not there then generator should start when the battery voltages go down to 47 volts.
In the evening and at night first source should be utility second should be battery and when the battery voltages get down to 47 v generator should start.
1) Solar
2) Utility
3) Battery
4) Gen set
Sounds straight forward to me. Set the genny to start if the voltage drops to 47. It won't get to 47 if the utility is working.
3310 watts panels, Classic 200 controller, 8 Surette S530's, Xantrex 5548 inverter, Honda EX5500 backup Genny.
