6V golf cart batteries
dyuhasdyuhas Posts: 1Registered Users
When I combine 2 6V batteries I get 12V.  Do I also get twice the amperage of a single battery?
  • PhotowhitPhotowhit Posts: 4,447Solar Expert ✭✭✭✭
    No, in series (connecting the positive of one to the negative of the other) the amperage remains the same and the voltage increases.
    In essence you are just building a bigger battery, a 6 volt battery is really 3 - 2 volt cells hooked up in series, your just making a battery with 6 cells.
  • soylentgreensoylentgreen Posts: 104Solar Expert ✭✭
    It's not 100% clear to me what the OP was asking, so I could see two possible answers:
    "No":  Two 6V golf cart batteries, each, say with 220 Amp Hours, wired in Series, will give you 220 Amp Hours (at 12V).
    "Yes" : Two 6V golf cart batteries will give you a hell of a lot more amp hours than a single 12V battery of similar size (as these  tend to max out at about 100 Amp Hours).
  • Sixpack99Sixpack99 Posts: 1Registered Users
    actually watts / voltage = amps :)
    Outback FXR3648A in Grid-Tie mode;  48v @ 215Ah for emergency backup;  400 watts of Renogy Mono PV (soon to be replaced)
    "voltage times watts = amps"  - nope.     Dimensional analysis to the rescue!
    Let's see if I can get this right - it's been a while since I had this in school.
    • Volts = Potential Energy/Charge = N*m/C = kg*m2/(A*s3)
    • Amps = Charge / Time = 1C/s
    • Watts = J/S = N*m/S = (kg*m2)/s3
    So, in the example above:
    "voltage times watts" = (kg*m2)/(A*s3) * (kg*m2)/s3 = (kg2*m4)/(a*s6)  : not what we want.
    Instead if you look at power (watts), does it equal VA?
    Watts = (kg*m2)/s3  = VA  ?
    Let's look at VA
     VA =  V * A = (kg*m2)/(A*s3)  *  (C/s)
       =  kg*m2*C/(A*s3)
    Substituting in that we know 1A = 1C/s we get
       =  kg*m2*(A/S)/(A*s3)
    And the A's and one of the S's cancel out, leaving us with
      VA = (kg*m2)/s3
    e.g, the definition of Power in Watts.
  • rcmatt007rcmatt007 Posts: 7Registered Users
    opps, you are right in any case, by doubling the voltage you can double the watts and still have the same amps
    I like to tinker... 5 and a half running motorcycles and a pile O'parts
    -Rodger-
