sun 228
ws9876
ws9876 Solar Expert Posts: 440 ✭✭✭
this pump says it needs 12-30 volts. Panels commonly have a 30v rating but a 37 voc
is this ok??? what panel would you use for this pump???
http://www.sunpumps.com/Products/SDS-D-228/
    You might need to contact sunpumps directly. Solar panels have almost a 2:1 voltage range from Cold Voc to Hot Vmp.
    Sunpumps would need to tell you if 12-30 volts is the Vmp range or the never to exceed voltage range.
