32v and 64v charge controllers
Wolf Harper
Registered Users Posts: 10 ✭
I have been asked to solarize other things around the railroad after the success of the caboose.
One is a locomotive (32 cells lead-acid, 64v nominal, 74v actual float voltage) simply as a battery maintainer, 1-2 amps tops, not much room for panels.
The other is a coach (16 cells lead-acid, 32v nominal, 37v float) to provide car interior lights and headlight same as on the caboose.
My question is, where to get solar charge controllers for these oddball voltages? They absolutely need to do proper battery management (e.g. Not overcharging) because they are expensive batteries and the installation is permanent.
Check out the MidNite Charge controllers, the Classics. Also ask over onthe Midnite forum too http://www.midnitesolar.com/ and http://www.midnitesolar.com/Forum/index.php
Midnight can go that high I believe. For the 32V, the Morningstar controllers can be programed with a computer and a cable to 32V specs. But why have 2 different systems ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
