generator charging
oadkins
Registered Users Posts: 19 ✭✭
do I have to install anything between batterys and charge controller if I use gen and 45 amp charger on cloudy days. thanks from a newby
I guess I need a little more information... If you have a 45 amp charger then you would need a:
- 45 amps * 1.25 NEC derating = 56.25 amps ~ 60 amp breaker (or fuse) and rated wiring minimum.
Nope, I just hook the battery charger to the batteries. If the sun comes out while charging, you may hit the batteries with a pretty large charge, I can hear my genset unload as the solar kicks in and i just go and shut it down.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
