Need BIG HELP choosing Charge Controller Please?
Hello guys. I need help here finding the right charge controller or controllers please.
Here is the run down(keep in mind I DO have fuse, fuses, breakers installed in all necessary locations). Ok, I have a 30' Toy Hauler/RV. The RV has [8] eight 250 watt panels on roof(38voc @ 8.75A), I ran #8 THWN-2 straight down to combiner box(parallel)...[ "Insert CC here" ]....Ok, so after CC will be charging 12 volt battery bank(1,200 a.h.), then Xantrex 2000watt inverter. And before we get on the subject, yes, I know this is alot of output amperage. I know I could go up in voltage to drop inversely proportioned amperage down but I need this system to be 12 volt....because the RV lighting, pumps, etc are already 12 volt, appliance are 12 volt, etc.
So here's the big question= do I use one big CC like Midnight classic 150, or do I split it up and use two CC together on one battery bank like the Xantrex mppt60-150 ? ...Or will either of these even work the way I'm seeing it? ...I'm exhausted, my brain is fried, help please.
  • westbranch
    Go to a higher voltage bank and use a stepdown converterto keep a 12V battery charged to power all your 12v stuff, or you can even use a small Morning star PWM CC to do it... AS to the 1200Ah 12v battery how were you going to get that Amperage? With multiple batteries? More than 2 in parallel is not a recommended solution , lots of problems can arise...
    hth
    West Chilcotin, BC, Canada
  • zoneblue
    Each 80A charge controller, at 12V can only take 12*80 watts. Thus you will need 2 of those charge controllers. This is just one of the reasons we dont do 12v with 1kw+ of solar. Do as WB said spend less than 100 bucks on a DC converter for the existing 12v gear. Me personally i favour 24V for RVs, because most/many dc appliances can be got in 24V, so you can gradually convert. If you want to keep the DC stuff. 24V is compromise. 3kW+ you really need 48V.
  • vtmaps
    Welcome to the forum,
    I agree with westbranch and zoneblue... go to 24 volts. You can reconfigure your existing batteries to 24 volts (unless you have 1200 ah 2 volt cells), and you will only need one controller :D You will, however, need a new inverter :cry: You will also want to reconfigure your panels to be two in series.
    --vtMaps
  • Bigmotoxer
    Bigmotoxer Registered Users Posts: 6
    First off ,thanks guys for responding ,big help I've been dying over here. Anyway, Arrgh I don't want to buy another inverter lol. But it would save me from buying 2 CC. my batteries are 6v Crown 220AH btw(sorry forgot to mention that), so yes I have 12 of them, yes that's a lot of paralleling, yes I should go 24-48v. Tear/Sniffs
  • Bigmotoxer
    If I had a 2 strings of 8 battery bank(16 batteries, 48v), isn't it a fact that it's possible to still pull 12v off of one of the batteries?...they do it on 48v parade floats out here @Disney. ...anyway just thinking ,I'll probably go 24v tho
  • Bigmotoxer
    Last thing, please if anyone knows best-bang-for-the-buck 24v 3000w pure sine inverter let me know asap I'm about to order something.
    BB. Super Moderators, Administrators Posts: 33,443 admin
    Would you use an Inverter-Charger (AC input for utility/generator charging)?
  • Bigmotoxer
    WHAT IS THAT THING?!
  • Vic
    Bigmotoxer wrote: »
    Here it is boys n girls wow!!!!!
    Hi Bigmotoxer,,
    IMO, you need to AVOID that "Charge Controller" -- at best, it is only a Diversion controller, with very limited flexibility, from a company that has a number of Better Business Bureau COMPLAINTS about MISLEADING customers, and not allowing customers to return merchandise.
    YES, 24 V is much better than is 12 V, and as zb mentioned, perhaps even 48 V. AND zb's reference to a DC/DC converter, which is a very good way to convert higher battery voltage to 12 V for the RV infrastructure items.
    EDIT: Here is a link to the BBB's Complaint history ... some complaints may have been resolved, have not studied it in detail this year:
    http://www.bbb.org/southwestern-missouri/business-reviews/solar-energy-products-retail/missouri-wind-and-solar-in-seymour-mo-32908/complaints
    Opinions, Good Luck, Vic
  • vtmaps
    Vic wrote: »
    Don't be so gentle Vic, tell it like it is... that thing will ruin his batteries. Also, it is necessary to have an alternate dump load in case that thing faults.
    --vtMaps
  • westbranch
    Look to Cotek... http://www.cotek.com.tw/product/18.html...
    I have an ST 1500 24v hardwired model. check out the specs of the 2500 model http://www.cotek.com.tw/upload/PDF/ST2500.PDF
    their SK 3000w model is not hardwired if that is an issue...
  • zoneblue
    RV folk seem to like magnum. A midgen cheaper than outback i guess. But yeah if you dont need the charger, Xantrex, Exeltek, Cotek, Samlex are the better of the mid range stuff. Stay away from the cheap stuff.
  • Bigmotoxer
    Thanks guys, thanks Vic. Westbranch and zone I'm looking at Cotek...maybe samlex
