Smart Grid, Mini-split heat pumps, and energy control
Dave Angelini
Solar Expert Posts: 6,752 ✭✭✭✭✭✭
Looking for ideas on this project. Below is a letter to one of my contacts at Schneider. I hope it will be of help to someone!
Hello Roy,
I just wanted to thank-you for the informative webinar on the CSW the other day. We may have met before at one of the Trace/Xantrex shows a ways back. My name is Dave Angelini and I heard you say in the webinar you like challenges. First I would like to give you some background on me. I am an electrical engineer from the Test and measurement industry, Aerospace, and Marine electronics.
My Wife and I have been offgrid for 23 years and I run a small business called Offgrid Solar that is world-wide consulting and some local work up here in the California Sierra mountains near Yosemite national park. I have over 70 happy offgrid homes under my belt. I also have worked with Xantrex Jeff Everett on the mppt-60 controller and beta tested with Jeff Fieldhouse on the mppt-80-600.
Here is what I am looking to do. I want to be able to run a Mini-split heat pump and control it so that when clouds start to build up it can throttle down the energy consumption. On the face it does not sound that hard but first some background. I was one of the first to do this for myself and my clients 7 years ago. The mini-split is the best use of excess energy that I know of for heating and cooling when the battery is charged or charging.
The way they work is when the programmed room temp is the same as the actual room temp they run using as little as 10 watts and up to their first power tier of about 300 watts. The second tier occurs when the differential between actual and programmed is about 2 degrees. At this point the mini-split can use between 400 and 500 watts. The last tier is when the differential gets to about 4 degrees and then the minisplit will consume about 800 watts. This data is from a 12,000 BTU / 1 ton unit with a SEER (seasonal energy efficiency requirement) of over 30. That is the current state of the art. The data will vary with size/SEER and it is here as an example.
Schneider has their smart grid equipment called Wiser. I have contacted the engineers there and while the Wiser system can turn-on or turn-off and set the temperature of a heat pump, it is not smart enough to throttle the thermostat up or down based on some other parameter such as voltage or ???. When I was working with Jeff we talked about a smart inverter that would know what the solar resource was (data from MPPT’s) and use the Aux to throttle up/down a thermostat, if there was one like this. There is always the catch as it is quite a bit harder to do this than it appears. I have made this short in hopes that you might know someone or like to get involved with this.
The project can lend itself to more than offgrid as I have customers who are XW based grid-tied and want to run max cooling or heating and not use the grid. When I hear the term Smart Grid I always think that my project here really is the Holy Grail of using renewable energy efficiently in all weather conditions. Most of my clients run 4 KW of tracked solar and want to set the desired temperature and leave the home knowing that if clouds come in and degrade the solar the system will not drain the battery much. They want just as much for the system to know the clouds have left and resume the heat pump conditioning space. A clunky Aux driven/solenoid shutting down the heat-pump is just too clunky, involves electricians, and really is not a smart use of energy as much is wasted in this strategy.
Thanks Roy! Hope you have a good week-end!
Dave Angelini / Offgrid Solar webpage below
Hello Roy,
E-mail offgridsolar@sti.net
A modbus thermostat and some software might just be the way to go here.Wireless Thermostat Controller, SWC-TSTAT-1Type:ControllerDescription:Spinwave Systems' Wireless Thermostat Controller is a drop-in replacement for almost any existing conventional non-communicating thermostat, re-using the existing equipment wiring. Thermostat functions and values are accessible remotely through an embedded web page of the Modbus Mesh Gateway or via Modbus communication. The wireless thermostat controller is a full function wireless mesh device with integrated radio that can be configured to control heat pump systems, (with auxiliary or emergency heating if necessary), gas/oil heating systems with add on cooling, control high and low balance points as well as the number of heating and cooling stages needing precise control. It can even adapt to manage the number of fan speeds it must control.Connectivity:Modbus, Modbus TCPFeatures:Celsius or Fahrenheit display; easy integration through industry protocols; scalable from simple to high-end applications with hundreds of wireless mesh nodes; auto season changeover; selectable programming or manual mode; heat cool or heat pump logic; add-on & emergency heat control; high & low balance points; single or 3-speed fan control; adaptive recovery; smart fan logic for commercial control; PIN protected menusSpecifications:Surface-mount; 24V powered with memory backup; accuracy: +/-0.3? C at 25?C; Radio: 2.4 GHz, IEE 802.15.4, transmit: 10dBm, receive: 0.0 dBm to -93dBm, transmission interval: min. 10 seconds, user configurable, open field range: 1400 ft
Schneider makes a modbus thermostat below.
http://buildingskb.schneider-electric.com/view.php?AID=7553
E-mail offgridsolar@sti.net -
I am making some progress on this project. Schneider keeps e-mailing me that there is interest but I think it is just PR and their way of putting off automating their systems to do something that really would be useful.
We have Alexa who has shown the most value here. Alexa is the Amazon Echo and she is pretty good.
Echo connects to Alexa, a cloud-based voice service, to provide information, answer questions, play music, read the news, check sports scores or the weather, and more—instantly. All you have to do is ask. Echo begins working as soon as it detects the wake word. You can pick Alexa or Amazon as your wake word.
http://www.amazon.com/Amazon-SK705DI-Echo/dp/B00X4WHP5E
My main concern with Alexa is she will not open the pod bay doors. She will tell me, "Dave I can't open the pod bay doors because we are not in Space"
I have asked Alexa to control the temperature of the mini-split based on voltage and she wants to control the thermostat (she can) but she asks for a temperature.....Someday....
