Parameters for PV effeciency
jahangir
Registered Users Posts: 1
Hi
I am working on hdf files related to solar radiation and there are lot of parameters in that. Some are related to solar panels and some are not. I just want to know if i have selected the right parameters. Following are the parameters:
EMIS = Surface emissivity
TS = Surface temperature, ALBEDO = Surface albedo, ALBNIRDF = Diffuse beam NIR surface albedo
ALBNIRDR = Direct beam NIR surface albedo, ALBVISDF = Diffuse beam VIS-UV surface albedo, ALBVISDR = Direct beam VIS-UV surface albedo
LWGEM = Emitted longwave at the surface, LWGAB = Absorbed longwave at the surface, LWGABCLR = Absorbed longwave at the surface with no clouds
LWGABCLRCLN = Absorbed longwave at the surface with no clouds or aerosol, LWGNT = Net downward longwave flux at the surface
LWGNTCLR = Net downward longwave flux for cloud-free sky, LWGNTCLRCLN = Net downward longwave flux at the surface for clear sky
LWTUP = Upward longwave flux at top of atmosphere (TOA), LWTUPCLR = Upward longwave flux at TOA assuming clear sky
LWTUPCLRCLN = Upward longwave flux at TOA assuming clear clean sky, SWTDN = TOA incident shortwave flux
SWGDN = Surface incident shortwave flux, SWGDNCLR = Surface incident shortwave flux assuming clear sky
SWGNT = Surface net downward shortwave flux, SWGNTCLR = Surface net downward shortwave flux assuming clear sky
SWGNTCLN = Surface net downward shortwave flux assuming clean sky
SWGNTCLRCLN = Surface net downward shortwave flux assuming clear clean sky, SWTNT = TOA net downward shortwave flux
SWTNTCLR = TOA net downward shortwave flux assuming clear sky, SWTNTCLN = TOA net downward shortwave flux assuming clean sky
SWTNTCLRCLN = TOA net downward shortwave flux assuming clear clean sky
TAUHGH = Optical thickness of high clouds, TAULOW = Optical thickness of low clouds, TAUMID = Optical thickness of mid-level clouds
TAUTOT = Optical thickness of all clouds, CLDHGH = High-level (above 400 hPa) cloud fraction
CLDLOW = Mid-level (700-400 hPa) cloud fraction
CLDMID = Low-level (1000-700 hPa) cloud fraction
CLDTOT = Total cloud fraction
FOLLOWING ARE THE SELECTED ONES: I think these parameters affect the solar panels.
Am i in the right direction?
Thanks in advance,
Regards,
Thanks in advance,
Regards,
If you really need to know/work with these details then you are either studying to be or already are a PV engineer. In such a case asking the questions on a general solar power forum isn't likely to elicit much response.
So let's go down to a simpler level: what exactly are you trying to do? -
jahangir,
posting late.
there is another aspect you are overlooking here. the solar cells output current that must be carried over fine filaments of wire imbedded onto the cell. the area these wires take up reduce the output of the cell and thus reduces efficiency. to minimize this one could use higher conductive filaments by the use of silver and making this a bit thicker rather than wider on the cell. of course one may make the mistake of spacing these filaments too far apart to effectively pass the currents needed so one can't just use less filaments without taking into consideration the resistive losses involved in that current needing to travel farther to get to the filaments. remember this isn't just about light collecting as we are trying to get electrical power from the light. solar can be used in thermal designs for heating water so what you've collected in your post can cover this aspect, but pvs go one step further which is why pvs are so much worse in their efficiency.
