shading solar panels
diop_ngaye
diop_ngaye Registered Users Posts: 2
hello,
I want to know the distance required between the solar panels to avoid shadows
thank you
  • Photowhit
    There is no safe distance if you put one in front of the other!
    Kinda depends on what latitude you live since the angle of the sun varies by your distance from the equator and at what time of year. so not only will the latitude, but the height, if mounted at an angle from one another and the width of each set for late day calculations.
    BB. Super Moderators, Administrators Posts: 33,440 admin
    Here is one site that seems to do a good job of explaining how to to make the detailed calculations:
    http://www.affordable-solar.com/Learning-Center/Building-a-System/Calculating-Tilted-Array-Spacing
  • diop_ngaye
    Thank you so much Bill
