Max Amp Charge Setting for Crown Batteries W/ Morningstar TriStar MPPT-60
KJ7YM
Solar Expert Posts: 30 ✭✭
I have a 24 volt system, with a 1000 W Solar Panel set. The Battery Bank consist of two strings of two 12 Volt Crown CR-185 Batteries. This system runs my home Refrigerator/Freezer while keeping the batteries at 20% DOD or less. It has been in service for a couple of months now, and I am quite pleased. When I was first setting up the system, I set the controllers max charge rate to 45 Amps, because the Crown documentation for my batteries said that they should be limited to 45 A. But since then I started thinking that with the 4 batteries set up as they are, may only allow the batteries to see half of the charge current as I am pretty sure they split the charge current in two between the parallel connection. Does this logic ring true to anyone else?
Yes, you are correct. Parallel connected batteries will each (on average) share about 50% of the current.
Assuming all is going well (no bad connections, matched cable lengths between strings, etc.).
