Forum Update - Can not edit signature to add system components
Anawa
Anawa Solar Expert Posts: 225 ✭✭✭
The subject says it all. When I went to my account settings to include my system components, after filling in the info, got an error message. Tried multiple times. Needs to be de-bugged.
Anawa
Paul
in Georgia
System 1: PV- 410w Evergreen, Mppt- Blue Sky Solar Boost, Batt - 225ah Deka AGM, 12v led house lighting,
System 2: PV- 215w Kyocera, PWM - Morningstar PS30, Batt- 225ah Deka GC's, 12v led house lighting, Dankoff 12v water pump,
System 3: PV- 1.5kw Kyocera, Grundfos 11 SQF well pump, 3000 gal above ground water storage, dom water & irrigation,
System 4: PV- 6.1kw Kyocera, Mppt- Outback FM80-2ea, Inverter- Outback FX3648-2ea, Batt- 804ah GB traction, Grundfos BMQE booster pump 240v, Mitsibushi mini-splits 240v, 18k and 15k
  • Anawa
    Here is the message: "{"errors":"unexpected_error","Required argument missing: signature"}"
    Also, screen freezes and only back button gets you back to user setting screen.
    Anawa
    Paul
    in Georgia
    Anawa,
    How long is your signature?
    Anyway, if you want, post your signature here (if you cannot edit the one I put in), and I will update it for you.
  • Anawa
    B.B. - Apparently my signature was too long. As you can see, after some trimming, it now fits. Thanks.
    Anawa
    Paul
    in Georgia
  • sdKev
    sdKev Registered Users Posts: 11
    Anawa, where is the sig function?
  • Anawa
    SdKev - Go to your user Account and scroll down about half-way and you will see a check box enabling signature. Within the same space, you will see Edit Signature. Use this function to add/edit your sig.
    Anawa
    Paul
    in Georgia
This discussion has been closed.
