Adding Generator Support - Should I use a Battery Charger or Inverter Based Gen Support
megawhat
Registered Users Posts: 3
Hi all,
Was hoping somebody here could give me a little guidance. I've done a lot of research, but need to fill the gaps a little.
I'm looking to put together a small mobile solar, generator assisted power system.
At present, my design looks like this:
Capacity - 2880Wh (generally a little lower than this, but I like safety margins)
Batteries: 450Ah (20-Hour Rate) @ 24V AGM
PV: 1.5kW (6 x 250W)
Charge Controller: Midnite Solar MPPT 60A
No Inverter - DC Loads only
Now, provided my numbers don't look too silly, my next task is to determine the best way to supply generator support, as it MUST also be automated.
My intention is to apply a bulk charge on mornings where solar insolation drops below 3 hours for more than a day (which is rare), just to keep the batteries freshened up (then let the PV panels take care of adsorption during the day). This is only for the winter months, temps are relatively warm and sun hours will approach 5+ in peak season. The system needs to be failsafe!
I'm not sure how to best go about interfacing a generator. I could use a 24V 50 or 60A battery charger with inbuilt PF correction and connect to a 3+ kVA generator (with auto-start), and an additional autostart controller or I could use an inverter with inbuilt generator support.
As far as I can tell, the inverter will incur power losses when its just sitting idle - am I right about this? I like the idea of the inverter option due to its autostart capabilities though. I don't have any need for AC at the site, so an inverter is otherwise surplus to requirement.
What would you do? If you did use a battery charger (instead of inverter), what would you use? How would you control the autostart?
I don't mind spending money on a decent solution, it has to be reliable. Ideally I would also like something with remote Ethernet diagnostics (but now I'm just being picky
Would love to hear your thoughts!
One place to look is for companies that make DC generators for telecom/CableTV/etc...:
http://www.alpha.com/index.php/critical-facilities-power/alphagen-generators/item/alphagen-telecom
The first ones I found are 36/48 volt--They may have 24 volt units available. They are autostart/remote unattended operation rated.
Thanks Bill, I'll check them out!
Can anybody advise as to whether I should look at using a 24V power supply, over using say an inverter to perform charging duties. I assume the inverter is less efficient??
Also, assuming I did use a power supply to perform charging duties, can anybody suggest any systems available for performing generator auto-start (2-Wire Operation). Are there any programmable controllers out there for this purpose. I can't find a whole lot.
Cheers -
Actually, some of the modern inverter/chargers are probably "nicer chargers" (more efficient, better power factor, more programmable) than a typical "dumb" battery charger.
Here are a couple of older threads with some Mfgs. of retrofit auto start generator controllers:
auto gen start
Auto Choke/ Propane Conversion
Automatic Generator Starting
Thanks Bill, your a legend!!Actually, some of the modern inverter/chargers are probably "nicer chargers" (more efficient, better power factor, more programmable) than a typical "dumb" battery charger.
auto gen start
I greatly appreciate your help!
- 620 Discussion Forums/Café
