are these 4 components campatible?
kennedy759
Registered Users Posts: 10 ✭
looking at a 24v system and are these components compatible as far as over or under capacity?
4 solar world 240w panels 2 series of 2
midnite kid controller charger
4 universal 100ah 2 series of 2
outback 2524 inverter
Re: are these 4 components campatible?
Well that array should be enough for maxing out the Kid on a 24 Volt system meaning 30 Amps.
30 Amps is more than enough to charge 200 Amp hours @ 24 Volts (the four 100 Amp hour 12 Volt universals).
Outback 2524 will have no trouble running off 200 Amp hours @ 24 Volts or recharging same.
I don't see any problems.
