Energy consumption listed and equipment I installed.... Sufficient?
squzzie
squzzie Registered Users Posts: 9
4-13watt bulbs about 1 hour runtime each
1 small fridge 1.3 amps run 5.6 startup
1- satellite dish box .5 watts 24hours
1- satellite receiver
1- 40 inch LCD television max 2.2 amps possible 4 hours per day
1- coffee pot single cup type unsure of usage? Used to make 2-3 cups a day.
Equipment
2- paralleled 435w 72.9v 5.97amps OPen=425w 85.6v efficiency rating 20.1
1- outback fm 60 charge controller putting out 24v
4- 6v excuse gc115g RC MIN @ 75 amps - 110 in series
1- 1500 watt continuous 24v inverter
Looking to add 4 more batteries
And have a 400w-2.2kw wind generator installed waiting on delivery of xantrax charge controller. But would like to rely on just the solar and generator just be a little extra.
    Re: Energy consumption listed and equipment I installed.... Sufficient?
    Need a bit more information.
    squzzie wrote: »
    1 small fridge 1.3 amps run 5.6 startup (amps at 120 VAC?)
    1- satellite receiver (amps or Watts at 120 VAC?) (leave up 24x7 or just when TV is on?)
    1- 40 inch LCD television max 2.2 amps possible 4 hours per day (amps at 120 VAC?)
    1- coffee pot single cup type unsure of usage? Used to make 2-3 cups a day. (amps or Watts at 120 VAC for how many hours per day?)
    If you can run the equipment, a Kill-a-Watt type meter would be of great help.
  • squzzie
    BB. wrote: »
    Everything is 120vac and yes receiver is only running when tv is on and coffee pot make only about 3 to five minutes total per day
