is my math right ?
System Posts: 2,511 admin
So i am trying to make sure I am not crazy, or that I understand how this works. if I live in florida and we get 5.5 solar hours per day and I have a 1KWH array ( 5x200 watt Panels) . I would get a daily yield of between 5.5kwh and 4.27 if I factor in .77 % of loss. If I use 4.27 as my daily number then in 30 days I have 127.05kwh of output per month and if power is .13 cents per kw then you have a total savings of $16.52 per month. Is this correct or am I missing something ? :confused:
Thanks for any input.
    Re: is my math right ?
    Jim,
    Pretty much correct... You can get pretty accurate numbers by plugging in your data to this link.
    To figure out your cost per kWhr, try:
    Total Cost of system + maintenance over 20+ years / # of kWhrs per year * 20+ years = $/kWhr
    Using 20 or 25 years is about as far as you would want to go out...
    That's a good "seat of the pants guess". 5 kwh daily, to offset (I'll take a wild guess of 30KW daily useage) knocking your bill back to 25KW ! $5 a day ! But it will get better if rates go up.
