'NEW' Edison ''Iron'' Batteries - has anyone else seen .....
Ol'DudeOl'Dude Posts: 11Registered Users
I see there's activity in the former GE plant in Alachua, FL where GE made batteries for Black and Decker for many years.
The new people are building REAL Edison-type iron batteries, beefed up for solar applications and high current as opposed to running telephone systems. I don't know what Edison used for automobiles but I think those were lead.
Anyway, see: www.prweb.com/releases/IronEdison/USAbattery/prweb11887664.htm
From what little I've seen so far, I really want to know more...
Ol'Dude
  • PNjunctionPNjunction Posts: 762Solar Expert ✭✭✭
    Re: 'NEW' Edison ''Iron'' Batteries - has anyone else seen .....
    I'm sure Mike can help you on that. NiFe are very nice batteries if they fit your application.
  • jimindenverjimindenver Posts: 59Solar Expert ✭✭
    The store isn't far from me and it would be great to test them out on the RV, but at over $1200 per 100 ah, it's out of my league.
  • verdigoverdigo Posts: 427Solar Expert ✭✭
    Hope they are available and cheaper in a couple of years when my GC2s give up the ghost. From what I have read that 100 amp hours will give you 80 amp hours of use with none of damage done to lead acid batteries for that deep of a discharge. Hopfully just having a bit more competition will drive the price down as time goes on.
  • mike95490mike95490 Posts: 7,611Solar Expert ✭✭✭✭
    They are a niche product. I can run for 2 weeks in winter with less than full charge, and not worry about "sulfating" them, and only a few generator hours daily (small 3Kw genset) But there are other pains, such as heavy water usage, even in winter, and electrolyte changeout every 5-7 years. I'm not looking forward to inverting 95# batteries and dumping "lye" out into some container without splashing. No way to work a siphon into them. But they are forgiving of less than full charge cycles. (but I'm not sure of the claim to discharge 80% of the way to 0)
    mike95490 wrote: »
    I think I would get one of those plastic kiddie pools, and just dump them in it and let it evaporate.
  • Iron BranIron Bran Posts: 10Registered Users
    mike95490 wrote: »
    The new USA Series NiFe batteries have a patented electrolyte mixture that will last the life of the battery. The manufacturer expects this new battery to get over 10,000 cycles, and the electrolyte will never need replacing.
    Also, the USA Series NiFe batteries include an integrated watering system which makes maintenance a lot easier.
    Attachment not found.
    Iron Bran wrote: »
    I doubt the watering system will fit my cells, but would the electrolyte be available to end users if compatible with generic NiFe cells? (as pre-mix or powder?)
  • westbranchwestbranch Posts: 5,009Solar Expert ✭✭✭✭
    "The electrolyte used in the NiFe battery also includes lithium hydroxide, which can improve the battery's performance"
    the addition is also found in the KOH mix used in 'wet' NiCd batteries.
    West Chilcotin, BC, Canada
    How do you size a NiFe battery bank for capacity considering the difference in DOD from FLAs? I have read claims of an 80% DOD capability, but there is also the need to be able to recharge in a day. My batteries are about a year old and have had no real use, but I really like the idea of forever batteries or at least the rest of my life.
    Sizing the NiFe bank. Several things. Higher cell resistance, so to reduce voltage droop, you have to over-size. There are resistance/amp tables for the different size cells. Lower power in winter, when cells are cold. Does that matter to your install ? (Baha or Canada) How large of a battery can you lift (with electrolyte) to turn over and dump out when changing electrolyte ? (although these new ones claim to not need changes). Big cells = big terminals, I had to make my own lug adapters, could not find any, anywhere.
    For recharge, assume 70% efficient, if you use 100AH, you have to replace with 130ah. That's a 10% larger PV array then flooded lead acid.
    But when the clouds come in winter, and charging is scarce, you don't have to run the genset for 6 hours to get up to 85% to prevent sulfation, for 2 or 3 weeks at a time.
  • feedhornfeedhorn Posts: 103Solar Expert ✭✭✭✭
    mike95490 wrote: »
    Oh the joy I'm having using my Lithium Iron batteries with 99% efficiency. Its like my solar array just got bigger all by itself. And the lack of significant voltage droop is so good too.
    Lithium Iron batteries has to be a typo right?
    verdigo wrote: »
    Not necessarily: LiFePo - Lithium Iron Phosphate
