Running a sprinkler pump
Zwygs
Registered Users Posts: 1
Hi,
I am looking at running a 1HP sprinkler pump off of solar power. I am currently using a Flotec FP5162. I am wondering how many solar panels I would need to run this, and approximate price. I normally run it about 1 day a week and for the whole day. I also normally only run it while the sun is up. I am trying to see if it would be worth investing in solar for the pump, or if it is just cheaper to keep running it off my house electricity.
Thanks.
Thanks.
Re: Running a sprinkler pump
Welcome to the forum.
Without even doing the math I can tell you there is a greater than 95% probability that running off your household power is the cheaper option.
1 HP is not an exact electrical power rating. Technically it's 746 Watts, but I've got a 1 HP pump that draws 1200 Watts running. The short math is even at $1 per Watt for inexpensive panels (not including inverter and associated components) you'll be investing quite a lot to run a pump for one day a week. The rest of the time your investment sits there returning nothing.
Other options: look for a different pump that meets your needs with lower power demand; invest in a grid-tie solar power system that will offset your power demands whenever the sun shines (you need to find out what your local utility's policies are on this).
- 898 Solar Product Reviews & Opinions
- 654 Solar Water Pumping
- 620 Discussion Forums/Café
