Excel PV Program Anyone have?
adas
Solar Expert Posts: 136 ✭✭✭✭✭
Aloha: Anyone out there make a excel program to show calculations? ie: input voltage or wattage or hours of sun, panel size, inverter effeciency etc. and get calculations filled in. You know, the fun stuff!!!
thanks
Frank
thanks
Frank
Re: Excel PV Program Anyone have?
The PVWATTS website kind of does 90% of the work... I just use the default 0.77 derating factor for Grid Tied systems and use 0.52 for off grid systems with flooded cell lead acid batteries and 85% efficient inverters...
Just take 0.77 overall * 0.85 inverter * 0.80 flooded cell batt = 0.52
You can also output the PVWATTS program in CVS and it will give you 365 days of hour by hour watts/m^2 so you can setup your own detailed spreadsheet.
A lot of the stuff is basic math (using P=IV, E=IR and variations). Most of the stuff I have posted included formulas for battery sizing, array sizing, load sizing, etc...
And those were derived from the general requirements and rules of thumb we use around here...
Many times, it is not worth going for 0.1% accuracy when, in real life--+/- 10% is close enough. And many of the other decisions are Code Related (fusing, wire sizing, conduit fill, etc.) where you pretty much need the NEC or local building code used by your town/county.
What exactly are you looking to calculate?
"What exactly are you looking to calculate?"
Everything!!!! I am a bit of a techie so I like to know info on all aspects of the system.
Frank -
Re: Excel PV Program Anyone have?Aloha: Anyone out there make a excel program to show calculations? ie: input voltage or wattage or hours of sun, panel size, inverter effeciency etc. and get calculations filled in. You know, the fun stuff!!!
thanks
Frank
Check my September 10th, 2007 attachment, it does all that and more.
Cheers,
Bad Apple -
Aloha, Bad Apple. Got it, looks interesting, thanks
Frank -
Direct link to that post :
http://forum.solar-electric.com/showpost.php?p=7941&postcount=11Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
