Max Wattage for a C60?
jcheil
Solar Expert Posts: 722 ✭✭✭
If someone wanted to max out a C60 controller at 24v what should be used as the guideline for that calculation?
They will be using true 24v panels (2 true 12v in series). Should it be based on wattage, or IMP rating or Short-Circuit Rating?
I know the controller states 60amp continuous, and above that it cycles on and off to protect itself.
Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html
Re: Max Wattage for a C60?
Maximum current of the controller (60 Amps) times Vmp of the panels (35 for 'true' 24 Volt panels). Id est: 2100 Watts. -
Re: Max Wattage for a C60?Cariboocoot wrote: »Maximum current of the controller (60 Amps) times Vmp of the panels (35 for 'true' 24 Volt panels). Id est: 2100 Watts.
Thanks so much. I had guessed that at being the proper calculation but I figured I would ask since I am still/always learning.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html
