Energy Star Tier 3 and better 20+ cu ft refrigeration
Dave Angelini
Solar Expert Posts: 6,746 ✭✭✭✭✭✭
Anyone with experience searching for the Tier 3 and better refrigerators? I am finding that the bottom freezer units use more energy that the top freezers. This does not seem correct to me. Tier 3 and better are fairly new classifications for low consumption. Tier 3 units do not defrost on a timer but use a sensor to determine if the defrost is required. Other things also go into this class.
The units I found were 363 KWH per year for a 22 cu ft top freezer and 430 KWH for a 22 cu ft bottom freezer.
E-mail offgridsolar@sti.net
Re: Energy Star Tier 3 and better 20+ cu ft refrigerationDave Angelini wrote: »Anyone with experience searching for the Tier 3 and better refrigerators? I am finding that the bottom freezer units use more energy that the top freezers. This does not seem correct to me. Tier 3 and better are fairly new classifications for low consumption. Tier 3 units do not defrost on a timer but use a sensor to determine if the defrost is required. Other things also go into this class.
This 21.9 cu ft bottom freezer unit used about 404 per year which was about 40 more than a top freezer. Still pretty low usage though.http://www.homedepot.com/p/203534763?N=5yc1vZc3piZ2bcre1Z1z0y90h"we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
When I was shopping for a fridge 2.5 years ago I too found that the bottom freezer units used more power than the comparable ones with a top freezer. We have a basic 18 cuft GE that is rated for 311kWh/year. When we first got it I measured it's summer consumption and it was pretty much right at the rated amount, 0.85kWh/day. We had to get it serviced about a year ago and I believe the tech put a little too much refrigerant back into it. It now consumes ~1.1kWh/day during our hot northern summers but only 0.5kWh during the winter. Yes, our kitchen floor is very much on the chilly side of things. -
Re: Energy Star Tier 3 and better 20+ cu ft refrigerationWhen I was shopping for a fridge 2.5 years ago I too found that the bottom freezer units used more power than the comparable ones with a top freezer. We have a basic 18 cuft GE that is rated for 311kWh/year. When we first got it I measured it's summer consumption and it was pretty much right at the rated amount, 0.85kWh/day. We had to get it serviced about a year ago and I believe the tech put a little too much refrigerant back into it. It now consumes ~1.1kWh/day during our hot northern summers but only 0.5kWh during the winter. Yes, our kitchen floor is very much on the chilly side of things.
I bet it is chilly now in Yellowknife! Not to great down here with 25F in the morning with bone chilling pacific humidity finding a path into the mountains.
I found a 21 Cu ft Whirlpool top freezer that uses 360 KWH and with the tier 3 attributes. I was told by the appliance guru on a Sears chat line that it all should be decided by if you make alot of cocktails. If you do, you need a top freezer.
Spring is coming!"we go where power lines don't" Sierra Nevada mountain area
Re: Energy Star Tier 3 and better 20+ cu ft refrigerationDave Angelini wrote: »decided by if you make a lot of cocktails. If you do, you need a top freezer.
?? I guess he doesn't like to bend over for those cubes...;)
I just wish some firm would offer an economizer option for a home refrigerator that would use outdoor air for cooling when the temps were low enough. An inventor over in VT does it for freezer cases in stores.
