Primus air 40 hookup questions
Poolguy
Registered Users Posts: 10 ✭
I am thinking of purchasing an air 40 to experiment and mess around with. I am confused as the literature says that the charge controller is built in. Do I just hook this directly to my battery bank? I have solar now with a charge controller and could I just hook this directly to the battery bank and not damage my existing solar charge controller?
Also if I use a stop switch, does this use some current to keep the blades from rotating? How much? If I have the stop switch off for say days or weeks how does that work?
Any help or insight would be very much appreciated!
Re: Primus air 40 hookup questions
In general, you just connect the wind turbine (with internal charge controller) to the battery bank.
If you want a stop switch, you usually use a double throw switch. First position power from + turbine to + battery bank (and fuse/breaker).
Second position, power from turbine + to turbine ground--That short circuit current (should) put a lot of torque on the turbine and stall the blades.
See page 21 and beyond in the Primus manual:
http://www.primuswindpower.com/files/9713/7107/4681/Primus_Air_Manual_4-2013.pdf
