Connecting 12v based wind system to 48v based solar system
cpfl65
cpfl65 Registered Users Posts: 4
Hi,
Does anyone have any thoughts on how to connect a 12v wind turbine system (12v battery based) to a 48v solar system (48v battery based) to act as a supplemental charger?
It had occurred to me that since I occasionally hookup my 6KW gas generator to the AC input on the Magnum Energy Inverter/Charger, that the AC output from a PSW inverter connected to the wind turbine system might work.
Comments?
Chris.
    Re: Connecting 12v based wind system to 48v based solar system
    About the only way I could see this working correctly--Is to use a battery charger (12 to 48 VDC or an AC inverter+AC battery charger) to step up the voltage from the 12 volt system to charge the 48 volt battery bank.
    Not cheap, and a fair amount of extra costs (chargers, 12 volt battery bank, conversion losses, etc.). I don't think you will get "useful" output from a typical 12 volt turbine by connecting it to a 48 volt battery bank (I have seen some vendors claim you could do exactly this over the years).
    It is possible that the turbine could be re-wound to 48 volts--But, from what I understand, not many small turbines have the room to rewind to a higher voltage.
    Unless your 12 volt wind system generates a lot of power--It probably is not cost effective to do this unless you already have a 12 VDC Inverter setup that could be used to power a 48 VDC charger.
  • NorthGuy
    NorthGuy Solar Expert Posts: 1,913 ✭✭
    If you have several turbines, you can connect them in series (after rectifying) to increase voltage. While doing that you need to make sure they're not connected to common ground.
    I would suspect that connecting multiple independent wind turbines in series is really not the way to go... It would then require 4 of them to all be spinning at near the same RPM to each share 1/4 of the output energy.
  • cpfl65
    The Magnum Energy Inverter/Charger has built in AC coupler circuitry that allows charging the 48v battery bank from a 120v or 240v source. I use it already for hooking up my gas generator to charge my battery bank on overcast days.
    I am hoping that it might be possible to use the AC output from a separate 12v wind turbine system (with a 120v AC inverter) as a direct replacement for the gas generator.
    The intended use of the wind turbine system is more for overnight load maintenance rather than full on charging. I would be happy with 3-5 amps per hour overnight. Every little helps.
