Storing wind mill energy in something other than an electric battery
pengyou
Registered Users Posts: 2
Has any research been done recently on storing wind mill energy in something other than an electric battery - such as pressuring a hydraulic tank? or air tank? What are terms that I can use to google this idea?
Re: Storing wind mill energy in something other than an electric battery
compressed air energy storage
pumped hydro energy: storing energy by pumping water between 2 dams/lakes/tanks at different heights
Interesting reading, but I think you'll find that the most economical storage in terms of $/kWh/year is the good old lead acid battery. -
There have been many types of projects that stored compressed air (from air tanks and wind powered air pumps) to large underground salt caverns (compressed air has been used as feed air for natural gas turbines--increases efficiency/shaft horse power because the turbine does not have to run the turbo compressor while using "pre-compressed" air).
Compressed air storage in tanks
Compressed Air Energy Storage in Salt Caverns
Pure hydraulic storage (accumulator in a vehicle size system) is probably best for storing small amounts of energy. Such as braking energy for delivery trucks:
http://fleetowner.com/running-green/hybrid-hydraulic-delivery-trucks-arrive
Unless you include reverse pumping for stored water behind dams... Then you have very large scale energy storage with a known infrastructure (reversible hydro electric power).
Pumped-storage hydroelectricity - Wikipedia, the free encyclopedia
One thing that always seemed a bit odd/over hyped were compressed air only powered vehicles.
MDI Enterprises S.A. - Air compressed cars - Flowair - Clean cars
and there are projects that are more of the "Prius" compressed air versions (storing braking energy/short distances):
A Hybrid Car that Runs on Air | Peugeot Citroen Uses Compressed ...
There are other uses for Wind Turbines that drive small air compressors... For air lift pumps:
http://www.koenderswindmills.com/Koenders_Windmills_FreeAir.html
Brumbert Airlift Water Pump - YouTube
So, what is it you are looking for?
