Breaker or Fuse?
Crystal
Solar Expert Posts: 128 ✭✭✭
I have a setup using a breaker box that's bonded. Is it all right to have batteries coming into their own breaker to feed the system, or should I have the batteries coming into one of the main bonded posts with a fuse close to the battery?
If I can use the breaker what should it be rated for?
If I should use the fuse what inline fuse would be best and amperage for this battery bank?
I have four 6 volt T105 batteries wired series/parallel.
Thanks!
Thanks!
Re: Breaker or Fuse?
You might just want to put a couple Blue Sea post fuses on the battery posts. Then any wiring after that point is protected.
Rating would be according to the maximum continuous current expected.
