Question on 12v water pump and proper awg wire related to distance from battery
Heisenberg
Registered Users Posts: 23 ✭✭
I have a 12v water pump that is rated for 7.0 maximum amps
http://www.pplmotorhomes.com/parts/rv-pumps-water/shurflo-pumps.htm
Assuming I have this powered by my 12v solar battery bank, how would I determine the proper wire gauge to use based on the distance between pump and battery bank?
I do not have the exact "future" location of the pump figured out yet, but I am roughly guessing it will be close to 20 ft of wire run from pump to batteries.
Thanks:D
Thanks:D
Re: Question on 12v water pump and proper awg wire related to distance from battery
First, the wire has to be large enough to carry the current. That's not much of a problem for 7 Amps.
Second, it has to be large enough to keep the Voltage from dropping too low. This is figured with a Voltage drop calculator.
Now, interestingly, if the negative is carried by the vehicle chassis it's one big conductor so the V-drop should technically be calculated on "half distance" rather than a "round trip". So whereas normally across 20 feet we'd pick 10 AWG to keep the V-drop below 3% but under such a situation 14 AWG might be used instead. -
Even the "simplest" of questions always leads you into pages and pages of vendor information that never answer the "basic questions".
For example, what is a "12 volt" pump rated voltage? Finally, in the installation document, a debugging tip:Proper voltage with the pump operating (±10%)
So, we know the operating range is 10.8 to 13.2 volts (pretty narrow range at the high end--But nobody seems to have any complaints, in general).
Given the operating voltage of a 12 volt battery under significant load can be as low as 11.5 volts--Then the voltage drop for the wiring should be no more than 11.5-10.8=0.7volt drop. And the minimum fuse size is 10 amp recommended--So we can use 10 amps for our drop calculations (error on the conservative side).
Using a generic voltage drop calculator and 20' of wire run (this calculator assumes wire run is 2x entered one way distance), 0.7 volt drop, we get:
10 AWG @ 20 feet gives 0.5 volt drop.
Re: Question on 12v water pump and proper awg wire related to distance from batteryUsing a generic voltage drop calculator and 20' of wire run (this calculator assumes wire run is 2x entered one way distance), 0.7 volt drop, we get:
ElectricianCalculators.com has hardcore calculators. And you can enter any voltage you want (PV strings). It has 5 calculators in it. The one you want (because it has almost everything) is the "Table 310.16 and voltage drop calculator". "Voltage Drop Calculator" is a simpler screen that has only 1 tab and doesn't worry about code book wire ampacity. "Raceway and trough fill" is good for determining conduit sizes.
