Charge Controllers?
nu2solar
Solar Expert Posts: 28 ✭
We would like to run 6 135 panels splitting them- 3 panels to 1 c-35 controller and the other 3 panels to another c-35 controller. Then each controller will run to the same bank of batteries. We are doing this to be redundant. Can this be done?
Lisa and Mike
Lisa and Mike
Re: Charge Controllers?
Hi I run two C40s 1200 watts on each to a single battery bank . Ive seen 35 amps going in on each. The only quirk is that when the battery is full one unit will drop into float before the other, no matter how close you tweak the pot settings. I otherwise have had no problems.
HTH
